Thanks again fogtender . Heres a few pics of what I,m guessing are the adjustments on the loader as well as for the remotes . Theres not one on the pump itself that I could see . If you need better pics I can get them I like the sound of backing it off as I haven,t got a pressure Gage yet .
I the above photo, the cover over the Allen head adjustment is directly below the rubber boot. Make sure when you take the cover off, you have a wrench on the lock nut below it so you don't try to take them both off at the same time and score the threads..
Once the cover is off, loosen the lock nut with a wrench on it and the bigger nut below that one so you don't pull the relief assembly out and possibly mess up that O-ring. Then after the lock nut is loose, back off the Allen head (May have a screw slot) thread one turn, they put everything back. When you do get a gauge, you can then check it for the right pressure.
But it will lower your pressures until you can get the right pressure set in it. That will at least get you operating at a lower pressure until all is well.
