Another rescued J5
oldwrencher
Hello all, first post but been following for a long time! Found an old J5 in a hunt camp in Northern Ontario, couldnt say no. Very old tho, im guessing early 50's? thin bodied wore through, small spindles. But complete, original configuration and runs and drives.
Currently have it torn down to replace the tub with a heavier one and a frame and the 251 needs a head gasket at least but the water tube will get checked. Diff looks ok. but will need acouple tires too. Tracks seem ok for now but will need to replace or weld up some guides
My question is, this was used for plowing years ago, at one time, has cutout for control handle in side. But no coupling on crank for pump. And everything is gone. (not much room anyway). Does anyone know the orig winch set up, cant find any pics but still learning the site. Or what has worked for others?
Would like to build or find a non elec winch for her. Not going to beef up the spindles at least not right now but did notice the spring cans need some work.
I will post a pic shortly(before the teardown). Thanks in advance,
