Snow Trac Tires
How many do you need, are you willing to accept used but good condition, are you willing to accept a lower quality substitute, do you need rims and inner tubes or just tires?
boggie makes a full cast replacement urathane wheel i haave been thinking about them because my solid tires are busting up my wheels also a good replaceent tire is an aircraft tail wheel tire i think they are about 35 dollars each
teledawg
Does anyone know where to find replacement tires for the Trelleborg 600x100 tires? Any ideas would be welcome.
The Alpine Guide 4.50-16 is the best, easy to obtain, replacment for the Trelleborg 600x100 tire. It has a "slick" profile more like the Trelleborg T522 4.00-4 tires and is very heavy duty. They fit is a bit tighter in the track guides, but they seem to work well.
They are available here: LINK
JimVT
I was told goodyear has a 400 16 tire has anyone used it yet?
Jim
JimVT
Took your advice . it is way larger than stock . hard to get on the rim without some damage to the rim. Poor choice for me.
want to buy it?
Jim
MNoutdoors RIP
Wrong size in the video, should be 4.50-16
The model is called TF-8181 and is 4Ply.
Some owners cut of the ribs on the sides of the tire.
That's seems like a lot of work cutting ribs off why not use a
4.50x16 smooth Bombardier tire. They are 6 ply also the smooth
Is not as prone to the tire guides running up on them
nwerring
Good idea. I have to check if I can get them in Scandinavia.
MNoutdoors RIP
Although those will fit, not the best choice those are square shouldered tires
Yes they have a radius but not a full radius and have also the tendency of ride up in the tire guides in the snowtrac guides IMO
We have used and do sell both the alpine guide and the original Bombardier
Tire (true radius) close to the same price
Here is picture of the original Bombardier tire with (no air) also a little narrower to fit the guides better
300 H and H
So how much for a pair of the rounded radius tires??
PM me your phone number, easier than trying to find it please.. :smile:
jask
Europeans can also source the Continental 4.00-16TT AS front T9
I have the Bombardier tires on mine.
Helmsman38
Why a 4 ply ? are the 4 ply tires holding up to the tire guides ?
Helmsman38
How many plus is that tire
Helmsman38
Yes 6ply….. Some guys use a 4ply I don't think they hold up well tot he track guides
Cidertom
Chionophile
I just pulled pin on 4 of the bombardier 4..50-16 from MNoutdoors, will let the list know how it goes
MNoutdoors RIP
Re: Snow Trac Tiresd
Here is a picture comparison sent from Niels in Norway after we sent him some tires
The first on the left is the alpine guide tire second is the one we sent and third is the original snow-Trac tire he said the ones we sent are as close to original that he has seen and can't get anything that close in Norway
