bombi 1968 jw68 front drive
trail boger
Does anyone know what I should use to replace the fluid in the front drive system in this unit. Right now the oil looks red in color, not sure if it may be ATF.
300 H and H
JD Trans, hydorolic and brake oil...
Torque guard is I belive what they call it. JD 20C
MNoutdoors RIP
Bombardier did recommend ATF for a number of years we disagreed with them
We started using the trans hydraulic we sold a lot of ring and pinions when people used the ATF. In a small unit like a Bombi, not pulling a load maybe you could have got by with the ATF. But on the the harder working and pulling machine trans hydraulic or the cat TO4 is better. 30 weight is good for average
Use 50 weight in the summer and for the big machines pulling and hauling but
We have used trans hydraulic successfully on machines up to 45,000 pounds
