need help finding parts for 91 cu. in ford for 1404 imp
Ok guys heres the verdict. I tore down my engine and its salvageable. There are two parts that I am having little luck finding.
The engine is the 91 cu in v4 ford that was used in the 1404 thiokol imp. I would be interested in used, new or performance replacements. I found an aluminum replacement for the gear but it is 200+. I was hoping someone might have retired one out here and have some parts they will sell.
-Piston
-Cam gear (fiberous)
The piston is 90mm with the 5mm oil ring and I would like either one or a set of 4.
I will also need pan gasket and intake gasket and front timing cover gasket. I can make them worst case but if anyone has one or all of the parts I would be interested.
Everyone on here has been awesome so far, thanks in advance
Anthony
