Go Back   Forums Forums - Off Topic Forum FUN > Agriculture & DIY Forums > Tools & Tractor Implements Forum
Reply
Thread Tools Display Modes
  #21
Old 07-14-2018, 10:48 AM
TiredRetired's Avatar
TiredRetired TiredRetired is online now
The Big Kahuna
TiredRetired has a spectacular aura aboutTiredRetired has a spectacular aura about
Default Re: Looking for an "inverter" type "Quiet" generator ... suggestions?
Sounds to me the Generac unit will fit your needs given that sound output is a major consideration. Just bear in mind that even though parallel operation is not on your short list currently, it could become more important in a SHTF situation where not disturbing your neighbors is the least of your concerns.
I try to plan ahead.
__________________
Never Vote for a Democrat. They Want Their Slaves Back.
The Following User Says Thank You to TiredRetired For This Useful Post:
Doc  (07-14-2018)
  #22
Old 07-14-2018, 12:35 PM
Melensdad's Avatar
Jerk in a Hawaiian Shirt
FWIW I already have a Generac natural gas unit hardwired to the house.
Also both of the Generac units that I am considering above can be paralleled, together, should my future needs change.
__________________
- Ayn Rand
The Following 3 Users Say Thank You to Melensdad For This Useful Post:
Doc  (07-14-2018), jim slagle  (07-14-2018), TiredRetired (07-14-2018)
  #23
Old 07-14-2018, 12:43 PM
The Big Kahuna
Roger that.
__________________
  #24
Old 07-15-2018, 07:41 PM
Melensdad's Avatar
After much deliberation, reading reviews, comparing specs, considering the actual usages for the new generator, and getting the input from the peanut gallery here at FF, but still without any firm prices, I am 90% sure that I will be buying the Generac that I linked in the first post in this thread.
Not the cheapest generator on the market. Far from the most expensive. It will run everything my wife needs it to run, with a good bit of surplus available. It will likely run at 50% to 70% of capacity most of the time. It is quiet. It is an inverter type with clean energy. Its small enough to stuff in a corner in the workshop. Its light enough to lift should I need to lug it around, but I'll likely add a wheel kit so she can roll it.
So unless something crazy happens, my friend will be giving me a price tomorrow and I'll very likely be placing an order. There is an off-chance that I may pick up the slightly smaller, slightly quieter, slightly lighter Generac, which is actually priced higher ... but only if the price makes it too attractive to pass up.
The safe bet? >>> http://www.generac.com/all-products/...eries/gp3500io
The longshot? >>> http://www.generac.com/all-products/...series/gp3000i
Either way, I'll be happy the choice.
Can't see paying the big bucks for a Honda or Yamaha. Just don't really expect it to get enough use to justify those prices. This is not a do-or-die tool choice. Its a convenience. I need reasonable reliability and those other 2 brands are probably better, but I don't see the value for my wife's projected usage ... not even if she uses it 3 times as often as I project!
On the other hand I don't want to go with one of the cheap brands or one of the more traditional open frame units at lower prices because of weight and noise and size.
__________________
- Ayn Rand
Doc  (07-15-2018), Edgar10937 (07-16-2018), jim slagle  (07-15-2018)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Trump picks Climate "skeptic" + Fracking "advocate" as energy advisor Melensdad Political Debate Forum 4 05-20-2016 10:07 AM
Bill Bennett : "Vote Against" Obama "This Time to Prove You're Not an Idiot" Cowboy Open Forum 4 10-10-2011 08:24 AM
Dems carry "NAZI" and "HITLER" signs, deny it, then walk back to Dem campaign office Melensdad Political Debate Forum 2 09-17-2010 12:41 PM
