I suspect Bob is looking for the VW of tractors, not unlike what he drives.
Is a New Holland 2035 worth roughly $5500 more than a Bobcat ct235, both with FEL and similar features.
What kind of watch do you wear?
OK, got me on that one.
While I do have a couple cheap watches, a daily wear watch that is 'expensive' is often on my wrist. But I don't necessarily consider an expensive watch the equivalent to an expensive machine. An expensive watch is sometimes justified by gold content, hand cut gears, enduring craftsmanship, etc. It still just tells time. Now that said, I will spend money on a Breitling, RGM or Piaget, but not on a Rolex. Two machines that do the same job may not be equal, but may be similar enough that there is no need to spend the extra money, is the NH a Rolex or is it an RGM? Both can cost the same but one, to me, imparts real value and craftsmanship while the other, to the public, imparts status. I'm not about showing others what I have or don't have. To me the finest watches are often those that very few people know.
If I was a salesman then I could tell a lot about the person by the type of watch they were wearing.
A fancy watch may indicate that you:
A. Have lots of money
B. Care about quality
C. Want to appear to have lots of money
I don't wear my 'fancy' Seiko if I'm working outside. I wear my $9.95 Timex Ironman digital. That includes anytime I'm going anywhere and I may be doing work outdoors. What does that tell you about me?
FWIW, I consider a TAG to be a reasonably inexpensive watch. It is one of the watches I would wear while tractoring, mucking about in the yard, etc.
Then you should see my point.
This time we have a roughly 20% price spread between these two brands when compared with similar options. My question is, is one actually worth 20% more than the other? Brand value may favor the New Holland. Craftsmanship may favor the New Holland. Even resale/trade-in value may favor the New Holland. But to the tune of 20%?
Local dealer is only important if they are quality dealers. My local dealers are long established high quality dealers, so I don't need to search out distant brands/dealers.
My tractor has been back twice that I can think of. One time for a loader recall warranty fix, one time to have a rear remote valve installed. However, having a local dealer is just as important for the times that I need to go there for misc small parts, fluids, implement purchases, etc.
But now I am really beginning to re-think this whole potential purchase.
To step up over the CAPACITY of what I have, I have to step up in size significantly. My TC24d is heavy for its size, but I'm looking at going up to tractors that are substantially longer, wider and heavier and I don't know that I want to do that.
To trade up to the Kubota or Cub/Yanmar really does not give me any significant advantage in capacity.
To trade up to a larger NH or Bobcat gives me a significant advantage in capacity but also a significant size increase and that would eliminate some of the uses for the tractor.
BTW, the Bobcat demo has been pushed off to TUESDAY of next week. In between now and then I will go back to Kubota and NH and see if I even want to pursue this upgrade by double checking the sizes of these tractors. When this quest started I wanted to upgrade to get capacity. When I really studied the next step up in machine HP and size I found that the capacity was already in my machine and there is no significant reason to go up the next step. That forces me to go up 2 steps and 2 steps in size gives me a real change in capacity but brings with it problems that caused me to choose my TC24d the last time I was shopping!!!
Less concern about weight, more concern about physical size.
No actually I don't, at least not with a TAG-Heuer. While they are good machine made watches, they run the price gamut from roughly $100 to Many Thousands of Dollars and mostly are fashion accessories.
