Thanks all for the feed back the reason for the upgread is I bought a electric over hydraulic steering situp from Boggie last year an just now installing it he tells me that with the amps that te pump pulls that running long distences it mite pull the battery down so if I am going to change the alternater I would like to get ride of the old regulator at the same time
Not to sound "Off", but why do you need that much more amps? Are you planning on putting a large amount of lights on it?
On my Imp, I did change out the old driving headlights with the newer Halgon bulbs and that increased my lights reach three fold. I still only made about ten miles an hour down the trail, so going so fast I would outrun the lights and run over a moose really wasn't an issue. I had two heaters, rear tail lights (installed them since there weren't any) and a backup light and one rotating beacon. Never had any battery charging issues with everything online. Didn't really drive a lot at night if possible, but we had a 40 mile run each way to the cabin and did so a couple of time at night.
I would like to increase the size of my altenator from the stock one on my 300cid ford (Thiokol 1977 1202 ) to possible and 80 amp with and internal regulator. Can amyone out there tell my the number of one that will mount up and how to wire it
The electric motor that runs the hydraulic pump will draw 80amps only mometarly but there are other items requiring power also so with a lot of turning it can run the battery down without a bigger alt.
