Go Back   Forums Forums - Off Topic Forum FUN > Agriculture & DIY Forums > Tools & Tractor Implements Forum
Reply
Thread Tools Display Modes
  #21
Old 05-04-2018, 11:04 AM
bczoom bczoom is offline
Style: T66
Default Re: Shopping for new pressure washer
A couple highlights that were lost.
When you look at brands, do an internet search for who owns the company. This helps in that you get an idea of the quality of the companies products as well as their sister companies who may have a similar product that may be offered at lower prices (because of the name brand it carries). Some pressure washers seem to have an identity crisis. E.g. Mine is a Troy Bilt. The plate on it says owned by Briggs & Stratton yet it has a Honda engine. To further complicate its identity, MTD owns Troy Bilt so why does it say Briggs & Stratton?
Just found this which may help:
https://pressurewashr.com/best-pressure-washer-brands/
Can you give us an idea of your main projects? If cleaning machinery and cars, I'm thinking you're looking at too big of washer. Anything over about 2500 PSI or 2.5 GPM may damage whatever you're spraying, especially painted surfaces or things not intended to get a lot of PSI (e.g. engine compartments). If you're using something as powerful as you're looking, be sure to stand back a bit and/or use the wider/widest angle nozzle. The jet nozzle will easily take paint off on even the small washers.
If you're still considering a Generac, look at their different models. The one you originally selected isn't one of their better models.
__________________
If you didn't hear it with your own ears or see it with your own eyes, don't invent it with your small mind and share it with your big mouth.
The Following 2 Users Say Thank You to bczoom For This Useful Post:
Doc  (05-04-2018), jim slagle  (05-04-2018)
  #22
Old 05-04-2018, 11:17 AM
EastTexFrank's Avatar
EastTexFrank EastTexFrank is offline
Gold Member
EastTexFrank will become famous soon enough
Bczoom, I think that we may have the same Troy Bilt power washer. I never realized it had an identity crisis. I will treat it more kindly and sympathetically in the future. :)
__________________
ETF
ďI won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them.Ē John Wayne as JB Books in "The Shootist".
The Following 2 Users Say Thank You to EastTexFrank For This Useful Post:
  #23
Old 05-04-2018, 02:07 PM
Doc's Avatar
Doc Doc is offline
Forum Admin
Doc will become famous soon enoughDoc will become famous soon enough
Thanks Brian. I appreciate your insights and the link (I searched but had not found that one). Great info.
I see why you simply said: Buy the Simpson. LOL
Much like when I bought a tractor with a FEL, I'm not sure what my main projects with the pressure washer will be. I know I have plenty of equipment to clean, plus cars n trucks, plus side by sides. I also will do the siding on the house once or twice a year. Plus the boat every week or two. Cleaning the concrete is the only project that I have heard needs full pressure.
So I plan to buy the higher pressure pressure washer and use the nozzles to back it down depending on the task.
Thanks again Brian, your info helped.
__________________
Scott me up Beamy.
Other Fun Forums:
Net Tractor and RTV Talk + Net Cooking Talk
  #24
Old 05-07-2018, 07:39 AM
Bamby's Avatar
Bamby Bamby is offline
Silver Member
Bamby will become famous soon enough
Style: T66_BiggerFont
I have personally used several different pressure washers. On the electric ones there simply isn't any choice the come with a simple on / off switch. But as of yet all the gasoline ones have come with a adjustable throttle that could be utilized to adjust pressure output for the task at hand. I run mine a lot at half to two thirds power unless full pressure is really needed.
__________________
Which is the gravest danger? Is it the ignorance, or is it the apathy of the average American today? Stumped? Hereís the answer: I donít know and I really donít care.
  #25
Old 05-07-2018, 08:05 AM
Doc's Avatar
Doc Doc is offline
Forum Admin
Right on Bamby. That is how my old electric power washer worked. It was 1300 psi.
Last night I ordered this simpson from home depot. Simpson
PowerShot 3,300 PSI 2.5 GPM Gas Pressure Washer Powered by Honda
Reliable high performance premium HONDA GX200 Engine
Maintenance free AAA Triplex Pump with PowerBoost Technology
Flexible and kink resistant MorFlex Polyester hose
I will pick it up at the store later this week. They would have shipped to my home for free but I read of to many shipped to the home that had oil all over the inside, and or the box damaged. So I will check inside the box before I leave the store.
__________________
Scott me up Beamy.
Other Fun Forums:
  #26
Old 05-07-2018, 08:31 AM
Style: T66
Sounds good Doc. Since we're spending your money, if that one only has a 25' hose, you may want to splurge and get something longer. I think mine is 25' and it's a PITA sometimes like when washing something large like the truck. It's hard to wash the whole truck without having to move the pressure washer so you can get the hose all the way around.
__________________
  #27
Old 05-07-2018, 08:33 AM
Bamby's Avatar
Silver Member
Pick yourself up some extra O-rings that are used in the nozzle and hose end fittings. And you may want to consider getting another length of pressure hose. If it's available choose the smooth skinned shinny hose it cleans so much easier at the end of the day and it's a lot easier to pull around all day to boot.
__________________
The Following User Says Thank You to Bamby For This Useful Post:
Doc  (05-07-2018)
  #28
Old 05-07-2018, 08:42 AM
Doc's Avatar
Doc Doc is offline
Forum Admin
I was planning on a longer pressure hose. Thanks for the O-ring suggestion. I will pick up some of those while I'm at the store.
__________________
Scott me up Beamy.
Other Fun Forums:
  #29
Old 05-07-2018, 11:05 AM
Style: T66
To keep your O-rings running for a very long time, lubricate them with Vaseline (or some kind of petroleum jelly). I'm still on the original set and it's probably been 15 years.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Pressure washer blues . BigAl Tools & Tractor Implements Forum 6 11-09-2010 12:56 AM
Pressure washer problem ??? BigAl Home Improvement Projects, Appliance upgrades, Misc Household items Forum 9 11-06-2010 09:11 PM
I need a pressure washer nixon Tools & Tractor Implements Forum 9 04-15-2008 03:59 PM
Whats wrong with my pressure washer XX%#??? BigAl Other Projects Forum 11 05-14-2007 07:31 AM
#$%#!@ Washer PBinWA Open Forum 13 01-29-2007 09:21 AM
