Go Back   Forums Forums - Off Topic Forum FUN > Agriculture & DIY Forums > Tools & Tractor Implements Forum
Reply
Thread Tools Display Modes
  #1
Old 07-02-2014, 01:50 PM
Radco Radco is offline
Junior Member
Radco is on a distinguished road
Default Chainsaw Tachometer
I have read a lot about you guys using a tachometer on the chainsaw. Which one's do you like? This will be for homeowner use not a pro.
Thanks
Rich
  #2
Old 07-03-2014, 12:36 AM
EastTexFrank's Avatar
EastTexFrank EastTexFrank is offline
Gold Member
EastTexFrank will become famous soon enough
Default Re: Chainsaw Tachometer
Never heard of such a thing. The saw either cuts or it doesn't cut. If it doesn't cut, take the chain off, sharpen it, put it back on and go back to work.
I don't particularly care what rpm the saw is doing, as long as the chips are flying, I'm happy.
__________________
ETF
I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them. John Wayne as JB Books in "The Shootist".
  #3
Old 07-03-2014, 08:27 AM
bczoom bczoom is offline
Style: T66
Are you referring to something like a Fast-tach? I believe they'll work on chainsaws but except for a service need, I wouldn't see the need for one. After awhile, you'll know if your saw is running at its top RPM (or not) just by listening. Normally, it'll start breaking up at higher RPM's if something is wrong.
__________________
If you didn't hear it with your own ears or see it with your own eyes, don't invent it with your small mind and share it with your big mouth.
The Following User Says Thank You to bczoom For This Useful Post:
Radco (07-03-2014)
  #4
Old 07-03-2014, 09:38 AM
Bamby's Avatar
Bamby Bamby is offline
Silver Member
Bamby will become famous soon enough
Style: T66_BiggerFont
This hast to a joke isn't it? There are so many critical things one has to observant of when running a chainsaw safely already. I can't even contemplate adding the observation of a tach to the mix.
__________________
Anyone else noted the irony of the best argument Liberal Democrats
can make for Abortion is the very existence of themselves.....
  #5
Old 07-03-2014, 01:07 PM
grizzer's Avatar
grizzer grizzer is offline
Silver Member
grizzer is on a distinguished road
Methinks consumer grade saws run 5-9K rpms with anti kickback chains & bars
Pro saws run to 11K rpm ginning up much more power.
  #6
Old 07-03-2014, 04:23 PM
mla2ofus mla2ofus is offline
Silver Member
mla2ofus is on a distinguished road
I see no need for a tach provided the chain is sharp and the operator is at least as smart as the saw.
Mike
__________________
Ol' Stonebreaker
The Following User Says Thank You to mla2ofus For This Useful Post:
EastTexFrank (07-03-2014)
  #7
Old 07-03-2014, 04:26 PM
Junior Member
Quote:
Tea something like the Fast Tach. But as other have said the need for one when adjusting the saw can be close enough to tune by ear.. So I save a few $$$ and listen better lol Thanks
  #8
Old 07-03-2014, 04:27 PM
Junior Member
Quote:
No not a joke but not looking to mount a Tach on a saw it would be to fine tune the saw as a lot of shops use them.. But I try by ear till I cannt hear anymore lol
  #9
Old 07-03-2014, 04:28 PM
Junior Member
Quote:
Mike
MIke LOL I know a few people who are not as smart as a rock :)
  #10
Old 07-03-2014, 09:43 PM
Silver Member
Quote:
I'll suggest ear plugs or muffs and you can still hear it well enough to get the carb set.
Mike
__________________
Ol' Stonebreaker
  #11
Old 07-03-2014, 09:51 PM
JimVT's Avatar
JimVT JimVT is offline
just a 2 cycle tac for the engine but one for the chain ,never heard of.
jim
__________________
Jim KF7RiN
#185 snow trac
2004 pistenbully canyon
  #12
Old 07-03-2014, 10:07 PM
Junior Member
Mike
I have the ear muffs that are mounted on my hard hat. I was kidding about the hearing ,as I am a old fart :) A Old farmer I knew could time a car by ear and to confirm it would hit it with a timing light, he was nuts on or pretty close. I am just new to working on saws so interested in things people use or do
  #13
Old 07-03-2014, 11:37 PM
Silver Member
I too am an old fart wearing hearing aids, so I try to preserve what little I have left. For two strokes I warm it up, wind it up to the nuts and turn the high needle out 'til it starts slowing down a little then turn it back in 'til it speeds back up. Let it back to idle and turn the lo speed in until it starts trying to die, then back out 'til it idles smooth. Squeeze the throttle all the way open quickly, if it balks then open the low needle 1/8 turn until it will rev up smoothly. Then set idle speed so the chain just stops. This may take a little playing back and forth between idle mixture and idle speed. You may also have to tweak the high needle slightly after this. Hopefully your saw is old enough you don't have the little plastic EPA stops on the needles. What a pain!! And some are hard to remove so you get so it runs right.
HTH,
Mike
__________________
Ol' Stonebreaker
Radco (07-04-2014)
  #14
Old 07-04-2014, 06:12 AM
Junior Member
HTH,
Mike
Mike great info Thanks. Very detailed My saw is new and yea EPA carbs , do not see those stops, I just need a splined socket type screw driver , which I ordered , I am planning on getting a older saw to practice taking apart and tuning. Had 2 at my Ex wifes house, So if I can find them I start there. if I screw them up no big deal, 1 is a old home light and the other is a Poulin , Something new for me to play with when I retire :)
Rich
  #15
Old 07-04-2014, 12:42 PM
Dargo's Avatar
Dargo Dargo is offline
Like a bad penny...
Dargo will become famous soon enough
LOL, after 4 shoulder surgeries I think I'd be more interested in an electric starter for my very well made old German Stihl chain saw that easily runs a 36" bar.
__________________
Still kickin'
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
The Aggie's new chainsaw jim slagle Jokes_Forum 9 06-10-2014 01:44 PM
Chainsaw Caddy Hercimer ATV's / RTV's / UTV's / Side-by-Side's Forum 9 12-14-2012 07:09 PM
Help me Nixon, I need a chainsaw! squerly Agriculture & Rural Living Forum 43 11-17-2012 03:08 PM
Chainsaw pirate_girl Jokes_Forum 4 08-22-2010 11:53 PM
Stihl 017 chainsaw help Mith Tools & Tractor Implements Forum 3 02-02-2006 10:54 AM
