Hey, after I've bathed in diesel fuel for two days now, does anyone know if you have to have a "pressurized" pump for one of the ****** ******* fancy ******* auto shut off nozzles to work??! After years of freezing my hands and getting cramps using my old fuel pump nozzle I decided to buy me one of those nice green diesel fuel nozzles that have the nice notches in them to keep the flow going and also the little thing a ma jig to automatically shut them off when the tank is full.
First off, fill your ******* tank after you **** with it; not before!! Anyway, I did my annual fuel filter change on my tank which, despite me always putting a 5 gallon bucket under, always manages to splash a quart or quart and a half of diesel on me and everything else close at hand. ***First Mistake*** (2nd if you count doing this with a full tank), I changed clothes and took a shower.
Next, I decide to install this great new ******* nozzle I just had to have! So, not being all stupid, I shut off the fuel petcock at the tank. Then, I figure that as long as I hold the fuel line above where it comes out of the tank, I should be able to use a couple of pipe wrenches and some pipe dope and change nozzles. I take my old nozzle off no problem and then bend over to pick up my my new nozzle. Shit!! I lowered the damn hose and again poured diesel fuel on everything, including myself! Okay, so I now install my new nozzle and get all the fittings tight. I then open the petcock and, wow, no leaks. So I go to try out my new nozzle and, zip, zero, nada, just a dribble of fuel comes out!
I check everything and all seems correct. I even bleed any air out of the system; none there. So, dip shit me, I go take a shower, change clothes and think about it. No reason comes to mind. Yeah, I decide to put my old nozzle back on. ****!!! I'm covered with diesel fuel again now, but it works just fine with my old nozzle. Does this mean that the auto shut off nozzles require a pressure pump to work? I have my tank about 10' in the air and have always used gravity flow.
Just let me know what you think while I go take another shower and change clothes again...
