Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Snowcat Restoration & Modification Projects Forum
Snowcat Restoration & Modification Projects Forum Major Restorations, Upgrades, and Non-Stock Snowcat Modifications
Reply
Thread Tools Display Modes
  #1
Old 01-26-2018, 09:14 PM
Fbmcurtis Fbmcurtis is offline
Junior Member
Fbmcurtis is on a distinguished road
Default Thiokol 2100b, cutting the tracks to make it more narrow?
Is it possible to cut the tracks down on a 2100b without it having issues?
The Following User Says Thank You to Fbmcurtis For This Useful Post:
vintagebike (01-26-2018)
  #2
Old 01-27-2018, 10:11 AM
LTR LTR is offline
Junior Member
LTR is on a distinguished road
Default Re: Thiokol 2100b, cutting the tracks to make it more narrow?
We narrowed our 2100C down to 10 ft wide, had to support the inside of the tracks because it was no longer balanced on the wheels. May sound crazy but we used treated 6x6 with 1"x 4" plastic screwed (countersunk) on top, tapered on the ends, and bolted on top of the axles. Grouser rode on plastic between belts, Correct height and width and very sturdy to walk on.
  #3
Old 01-27-2018, 10:48 AM
Junior Member
Do you have any pictures. Thank you for the reply!
  #4
Old 01-28-2018, 05:44 PM
LTR LTR is offline
Junior Member
We sold our Packmaster 2100C a few years ago, and I couldn't find any good pictures of the 6x6's, if you look close between the first and second belt, you can almost see the tapered end on top of the front axle. We welded small pieces on angle Iron to the front and back axles, drilled and lagged to 6x6. The 1"x4" plastic pieces screwed on top were tapered in front and back also, The lengths had to be just right that when the track turned forward or back, it would ride up level and not sag. Hope this makes sense!
The Following User Says Thank You to LTR For This Useful Post:
sno-drifter (01-28-2018)
  #5
Old 01-29-2018, 12:10 PM
Junior Member
Makes sense to me. Thank you for the advice it is greatly appreciated!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Cutting down wide tracks BearGap Snowcat Restoration & Modification Projects Forum 14 03-26-2016 11:43 AM
76' Thiokol 2100B, 86' LMC 3700, Modified Thiokol 2100C "Vancat" Peak Snowcat Classifieds (For Sale / Wanted) Forum 5 11-20-2012 10:09 PM
wts thiokol 2100b parts kehoe585 Snowcat Classifieds (For Sale / Wanted) Forum 3 02-25-2011 09:33 AM
WTS: Thiokol 2100B Custom petersonequipment Snowcat Classifieds (For Sale / Wanted) Forum 0 06-22-2010 10:01 AM
Thiokol 2100b Tires LittleWing THIOKOL/LMC/DMC Technical Issues Forum 6 01-07-2009 02:29 PM
