Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Snowcat Restoration & Modification Projects Forum
Snowcat Restoration & Modification Projects Forum Major Restorations, Upgrades, and Non-Stock Snowcat Modifications
Reply
Thread Tools Display Modes
  #1
Old 12-06-2017, 06:52 PM
Tigdim Tigdim is offline
Junior Member
Tigdim is on a distinguished road
Default New guy here, with questions.
Hello all,
I am new to these tracked machines and this forum. I always thought these were designed only to be used in snow as trail/ski hill groomers, not for use all year.
Then a few weeks ago I was researching vehicles for steep terrain, and came across some photo's of j5's and muskegs. Fast forward a few weeks and now I am on here looking for more information.
My reason for researching steep terrain vehicles is that the farm I hunt and cut firewood on has some very steep hills/bluff's. Think 70% grade. (we don't go on those except on foot) And a few areas 4 wheelers are tricky to get up out of with a single rider, putting a deer on the front rack helps a-lot. Can't even load the back of the ranger with un-split rounds and make it up the hills, much less pull a log or a trailer full of rounds with it. (40 or 50% grades??? have to go measure now)
Looking for a machine that can get in and out of the trails discussed above moving a log or 2 using an arch or possibly winching the log butt's up on to the back of the machine. Think J5 ram skidder.
First question, Anyone know the uphill downhill rating of the J5's? (www.safetyoneinc.com PDF for the J5 does have this spec listed ... unless I just missed it.)
2.) If the information I have found is correct, sprocket should be 11 tooth measuring 5.25" tooth to tooth, giving a total diameter of slightly more than 18 3/8". Is this correct?
3.) Anyone know the actual drive diameter of the sprocket? Or even just the tooth height?
Then I can subtract 1 tooth height from the full diameter of the sprocket to get the diameter at 1/2 the tooth height. Should be accurate enough for calculating speed and drawbar pull. (thinking or re-power an old body/tub, with hydrostactic drive, sort of like discussed here. )
http://www.forumsforums.com/3_9/showthread.php?t=46397
I look forward to becoming part of the community,
Aaron
The Following User Says Thank You to Tigdim For This Useful Post:
redsqwrl (12-07-2017)
  #2
Old 12-06-2017, 08:00 PM
GlacierSean's Avatar
GlacierSean GlacierSean is offline
GlacierSean is on a distinguished road
Default Re: New guy here, with questions.
MacGyver would make a slope degree measuring tool with a Protractor, string and a straw.
  #3
Old 12-06-2017, 09:23 PM
MNoutdoors's Avatar
MNoutdoors MNoutdoors is offline
Tracked Evolution Central
MNoutdoors is on a distinguished road
Here is a J5 sprocket, it will fit right over a small torque hub
Normal pitch on a J5 is 3.75 but thatís because of the drop center cleat changes the diameter of where the belts are.
__________________
Have a nice day, NSA kind of like NASA but one less "A"
The Following User Says Thank You to MNoutdoors For This Useful Post:
Tigdim (12-07-2017)
  #4
Old 12-07-2017, 12:17 PM
Junior Member
what is the bolt pattern for the J5 sprocket?
I assume, I will have to make an adapter plate to adapt from a torque hub to the sprocket, correct?
  #5
Old 12-11-2017, 12:13 AM
MNoutdoors's Avatar
Not with the correct torque hub just drill the pattern into the sprocket we normally drill the holes larger and Bush them for a larger contact area, then make a outside plate to match
This picture is not a J5 sprocket but the center is the same size and these are mounted on a torque hub. This is a Muskeg flat track sprocket that we make.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Questions about GMP Dolores Gutierrez Business 101 Forum 2 08-04-2017 02:26 PM
new to me ST4 questions Cidertom Snowcat Adventure & Usage Forum 15 01-18-2013 04:58 PM
301 questions MAD Snowcat Restoration & Modification Projects Forum 0 10-14-2010 09:02 PM
E-10 gas questions bczoom Oil, Lubricants, Engines & Misc Forum 15 09-04-2010 01:26 AM
More questions about st-4... snowmobile Snowcat Repairs, Parts & Problems Forum 5 11-05-2007 12:25 AM
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Copyright © 2002 - 2017 www.ForumsForums.com
