Thinking about making up a pressure gauge to measure the pressure on the zirk for the track tension.
Has anyone made one?
Does anyone know what the pressure should be?
I am thinking this might be a better answer then guessing if they are tight enough only to find out they are too tight. Foam filled tires make it a little tough to watch for indentations like the manual suggests. Also good for when someone else is using it.
Thanks,
Don
Thanks,
Don
