Wiper arms
moosebgy
What are the correct replacement wiper arms for the Snow Tracs? Did a search but I couldn't find any part number or are they just standard VW wiper arms. Since the snow level is coming slowly down the mountains I need to get ready. Thanks
Jeff
I don't know.
But I would be they are from a VW beetle or bus.
clhsmith
I WRAPED A WIRE ON THE ARM TO DETERMINE THE LENGTH NEEDED THEN WENT TO AN AUTOWRECKER WHO HAD A BIN FULL OF ARMS AND GOT THE RITE LENGTH. THE RODS THEY FIT ON ARE ONE QUARTER INCH WHICH IS TOO SMALL FOR ANY MODERN WIPER. I PUT A BRASS BUSHING ON THE ROD TO MATCH THE HOLE SIZE IN THE WIPER ARM THEN DRILED ASMALL HOLE THROUGH ALL THREE AND INSERTED A COTTER PIN .YOU HAVE TO DO SOME CHECKING BEFORE YOU DRILL THE COTTER PIN HOLE THAT THE WIPERS STOP IN THE RITE PLACE SIDE TO SIDE ON THE GLASS. WORKED OUT FINE. HOPE THIS HELPS C.S.
