Finally got some really cold temps and my garage heater craps out.
I only run the heater when the prolonged temps are below freezing and then only to bring the garage temperature up to about 40 degrees. My goal is simply to keep the stuff in the garage from freezing solid and to make starting the engines easier.
If I am working in the garage then I may turn it up to keep me warm, but that is only short term.
So now the fan turns on, and the fan runs, blowing cold air around the garage. The electronic ignition "clicks" continuously but obviously the gas burners are not lighting. Gas line is open so there should be gas flowing to the heater.
