Currently, our washer and dryer are in a closet off of the kitchen (one piece stacked unit). I am planning to put the new units in the basement so that we can re-claim the closet as usable space. The dryer is pretty simple, and the hot & cold water supply for the washer is straight forward too. The question I have is the drain for the washing machine.
So far as I can tell, I have three options:
- a 48" stand pipe down the wall and across the floor to the existing 4" floor drain.
- hard PVC connection to the washer with a check valve tied directly into the overhead drain pipes.
- a 48" stand pipe into an ejector tank (not buried) which will pump up and into the overhead drain pipes.
Obviously, the first option is by far the simplest and cheapest, but is it enough? I know the floor drain can handle a good volume of water, since that is the drain that takes all the water when I have had to drain the entire house.
edit: No gas line to run...all electric
