Snow Trac Parts
Stuart
I just purchased snow trac # 2012 from Breton Nova Scotia , Canada, I am in New Brunswick Canada. I owned two snow tracs in 1997 and sold them to a gentleman from Pennsylvania. Back at it again I am now looking for the following parts:
-track drive sprockets ( only 2 needed as 2 are new)
- small boggie wheels ( 2 needed -tires, rims, tubes)
- track guides ( 8 needed)
- axle housing ( the passenger side housing is broken where
it goes through the body into the engine bay)
I can make the track guides if necessary and possibly the axle housing can be welded , not completely sure as I have not removed it yet. Thanks-any information will be greatly appreciated.
the axle housng can be repaired by some one with a good tig welder which track do you have the 3 band or 2 band i may have some parts
unclebuck4571
Hello Stuart: I have a snow trac and some spare parts, and may be able to help you. I live in Charlo, N.B. Where are you located. Bob.
alaska120
Mayor McCheese
New outer drive sprockets can be had for about $200/ea from a foundry in North Pole AK.
T&J Foundry I think...He can make both styles.
alaska120
Mayor McCheese
Thanks Boggie. I was looking it up last night and noticed it was JT and not TJ...:biggrin:
I purchased four new sprockets from him a few years ago. They actually looked pretty good and have been working fine. The holes where they attach are not drilled. I was told that the studs are not always in the same place on every machine so they need to be done when you get them. All I did was clamp the old worn one over the new one and hit it with a drill press.
smitty
I have a1976 bodi i need drivers for it could i get the phone # from you to order a set Thanks Maurice
smitty
I am looking for drives for 1976 bombadier they are 9 tooth I would like to get 10 tooth if I could
