Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Snowcat Restoration & Modification Projects Forum
Snowcat Restoration & Modification Projects Forum Major Restorations, Upgrades, and Non-Stock Snowcat Modifications
Reply
Thread Tools Display Modes
  #121
Old 08-23-2019, 07:06 AM
DAVENET's Avatar
DAVENET DAVENET is offline
DAVENET is on a distinguished road
Default Re: 1542 conversion to a 1543 supersized project
Charge Air Cooler / Intercooler
  #122
Old 08-24-2019, 07:59 AM
olympicorange's Avatar
olympicorange olympicorange is offline
olympicorange is on a distinguished road
Quote:
……… so the B series ...3.9 …. uses an engine coolant intercooler...,mounted on top of cyl. head ...in place of the intake plate .
The Following 2 Users Say Thank You to olympicorange For This Useful Post:
Cidertom (08-24-2019), DAVENET (08-26-2019)
  #123
Old 08-25-2019, 08:34 PM
………... went for alittle ride to today ..to the PEAK.... stopped in to see what our pals had new & exciting on the lot … theyre busy...and a new model...
The Following 6 Users Say Thank You to olympicorange For This Useful Post:
DAVENET (08-26-2019), J5 Bombardier (08-26-2019), jim slagle  (08-25-2019), Northcoast (09-09-2019), Pontoon Princess (08-25-2019), wbuffetjr1 (09-02-2019)
  #124
Old 09-01-2019, 09:44 AM
........ took a few hrs. off last nite to watch the racing at the local track... and the previous owner of the tucker project... great fun Dave …
The Following 7 Users Say Thank You to olympicorange For This Useful Post:
jim slagle  (09-02-2019), Jphoenix (09-02-2019), nikos (09-04-2019), NorthernRedneck (09-01-2019), PJL (09-01-2019), Pontoon Princess (09-09-2019), wbuffetjr1 (09-02-2019)
  #125
Old 09-02-2019, 07:33 PM
………... happy labor day to all... got a little side tracked this afternoon, … helping my painter buddy billy … ( whom painted the old Littleton off-road riders tucker, in a previous post, with mr. loggah ) . on a project that he needs to finish...before we can start on my ol tucker....
The Following 3 Users Say Thank You to olympicorange For This Useful Post:
jim slagle  (09-02-2019), Jphoenix (09-02-2019), Pontoon Princess (09-09-2019)
  #126
Old 09-02-2019, 07:37 PM
,...….….. oh... these two 1971 's are for sale … 399 skidoo …. 292 arctic cat.... if anyone wants to add to their collection… thx ...
  #127
Old 09-03-2019, 06:35 PM
Track Addict's Avatar
Track Addict Track Addict is offline
Track Addict is on a distinguished road
Must be doing the drive cogs while it’s apart? I found cutting the rivers down through the worn nylon sprocket with a cutoff wheel on angle grinder then gingerly working the side plates of works best. Stainless nylons and bolts for the install.
__________________
Formerly Blackfin4Bluefin
The Following User Says Thank You to Track Addict For This Useful Post:
olympicorange (09-04-2019)
  #128
Old 09-04-2019, 10:00 PM
……….. finally arrived …. GM brackets...thx BFT... these are the bomb... let the welding begin.... decided to go with the same mounts as the engine....same...same.... simple...simple.....
The Following 4 Users Say Thank You to olympicorange For This Useful Post:
J5 Bombardier (09-05-2019), jim slagle  (09-10-2019), PJL (09-05-2019), Pontoon Princess (09-09-2019)
  #129
Old 09-05-2019, 12:45 PM
Blackfoot Tucker Blackfoot Tucker is offline
Blackfoot Tucker is on a distinguished road
Quote:
I'm glad that idea is working for you, and you were able to get the castings without too much trouble!
We just used some sections of rubber belting, roughly 3/8" thick, between the GM castings and the Tucker frame mounts. We cut the frame mounts down so they could be welded to the inside (rather than the top) of the Tucker frame. This mounting location allowed for excellent alignment off the transmission output and transfer case input. But, as you know, your situation my be different as the engine placement may dictate something else entirely.
(Really enjoying this thread!!!)
The Following 2 Users Say Thank You to Blackfoot Tucker For This Useful Post:
olympicorange (09-09-2019), Pontoon Princess (09-09-2019)
  #130
Old 09-09-2019, 08:40 AM
…….… yes, the shape of mounting brackets adds a lot of support. it took some serious ''leg-work'' , web surfing, emails, text, phone calls, etc... to locate a set. all the way from Stockton. the right side mount almost sets perfect to the frame. the left side will require alittle more Fab. work, due to the fact that the Allison doesn't align to the ''B'' perfectly straight /inline. it is slightly ''cantered'' offset in the bolt pattern. fairly common with a lot of diesel's . it was less of a drastic offset ..''CCW''...as opposed to the ''CW'' offset. so that will be the next task at hand.... thx again BFT....
The Following User Says Thank You to olympicorange For This Useful Post:
  #131
Old 09-09-2019, 09:14 AM
……….. wife's BDAY, off to her old stomping grounds ...Alway's entertaining... nothing like the ''Big Apple''..... ( so progress ''on hold'')...
DAVENET (09-10-2019), PJL (09-10-2019), Pontoon Princess (09-09-2019)
  #132
Old 09-10-2019, 07:57 AM
……. progress on tranny mounts ...fabrication....
J5 Bombardier (09-10-2019), jim slagle  (09-10-2019), sno-drifter (09-22-2019), Taxrulz (09-10-2019)
  #133
Old 09-10-2019, 09:01 PM
……..… and the tranny ''jig'' comes off....
The Following 5 Users Say Thank You to olympicorange For This Useful Post:
jim slagle  (09-11-2019), nikos (09-11-2019), PJL (09-10-2019), sno-drifter (09-22-2019), wbuffetjr1 (09-11-2019)
  #134
Old 09-11-2019, 12:07 AM
Northcoast Northcoast is offline
Northcoast is on a distinguished road
Well done!
The Following 2 Users Say Thank You to Northcoast For This Useful Post:
DAVENET (09-11-2019), olympicorange (09-11-2019)
  #135
Old 09-11-2019, 09:01 PM
……. put the rubber to it...…
jim slagle  (09-11-2019), Jphoenix (09-11-2019), PJL (09-11-2019)
  #136
Old 09-11-2019, 10:14 PM
PJL's Avatar
PJL PJL is offline
Looks like it's ready to fire off.
  #137
Old 09-12-2019, 07:19 AM
[QUOTE=PJL;20705498]Looks like it's ready to fire off.[/QUOTE
….. pretty close … yes... fluids, belt, batteries, exhaust, alittle wiring, … time to make some noise... and smoke....
  #138
Old 09-14-2019, 08:47 AM
…….... score....went ''pickn'' at one of my favorite supply yards...
J5 Bombardier (09-14-2019), PJL (09-14-2019), wbuffetjr1 (09-14-2019)
  #139
Old 09-16-2019, 09:13 PM
……..…. a better look at the ''spoils'' from the treasure hunt...
Jphoenix (09-16-2019), redsqwrl (09-17-2019), sno-drifter (09-22-2019)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1980 Tucker 1543 Cedar City Utah - Not Mine wannagoflying Snowcat Classifieds (For Sale / Wanted) Forum 2 06-17-2018 04:52 PM
Not mine----1543 Tucker with blade CoFarmer Snowcat Classifieds (For Sale / Wanted) Forum 3 05-23-2018 11:21 AM
Blade for 1543 Tye one on Snowcat Restoration & Modification Projects Forum 4 12-19-2017 09:25 AM
First run for 1543 Tye one on Snowcat Adventure & Usage Forum 7 12-19-2016 12:41 PM
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Copyright © 2002 - 2018 www.ForumsForums.com
