Ray
Da speks...
This is a BRAND NEW Pressure Washer manufactured in the USA
Comes complete with a 50' Non-Marking Hose, HD Gun, Wand, Spray Tips and MORE !!
This is a very solid unit with 14" tires and a Commercial Duty 13HP HONDA engine !
Has a CAT Belt Drive Triplex pump, with thermal relief valve, and chemical injector !
Description:
• BE Pressure Supply Extreme Cool Drive Edition
• Cooler Pump: Cool air is propelled over the pump reducing the heat by 25%
• Air Vents: Unique system draws cool air into the unit through the outer air vents
• Pulley System: Laser aligned patented pulley fanning system creates cooling air flow and help prevent slippage
• Industrial X-stream frame with pneumatic tires and solid welded anti-vibration rubber foot
• Solid and secure bolt-on tires with industrial grade threaded axle
• Quick Remove Cover: Belt guard removes easily in 20 seconds with 3 hand tightening knobs – No tools required
• Belt Drive
• PSI: 4,500
• GPM: 5.0
• 13.0 HP Honda “GX” OHV Engine (Commercial Duty with "Oil Alert")
• Cat 5CP3120 triplex plunger pump
• Easy-Start Adjustable pressure unloader with by-pass hose
• Thermal relief valve
• Safety relief valve
• Low Pressure Chemical injector
• 50’ Non-Marking steel braided high pressure hose with QC’s
• 5,000 PSI Heavy duty trigger gun
• 36” Insulated wand
• 3 Quick connect spray tips 0,15,40 and 1 soap nozzle
• All stainless steel frame with Stainless handle & hose hanger
• 14" Tubed foam filled no leak pneumatic tires
Quick-release stainless steel belt guard
Extra Special Features:
* Air Vents - Cool air is drawn into the unit through outer air vents
* Pulley system - Laser aligned patented pulley system creates cooling air flow
* Cooler pump - Cool air is being propelled over the pump, reducing heat by 25%
* Belt Guard - Belt guard not attached to frame, reducing vibration by 45%. Easily removed with no tools, using tightening knobs
* Aluminum mags - Industrial strength mags
* Flat free tires - These power washers have tires that are made of solid foam fill. There is no air and never a flat tire
• Weight: 270.0 lb.
• Ships via truck
I can now cut people in half, walking on the street in front of my house.........from my back yard.
Awesome!!!!!!!!
He he he
Description:
• Belt Drive
• PSI: 4,500
• GPM: 5.0
• Weight: 270.0 lb.
• Ships via truck
Awesome!!!!!!!!
He he he
