Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Tracked 4X4 Vehicles Forum
Reply
Thread Tools Display Modes
  #41
Old 03-22-2020, 08:07 PM
KickerM's Avatar
KickerM KickerM is offline
KickerM is on a distinguished road
Default Re: Suzuki mini truck on tracks
I probably should have mentioned they work really good in deep snow
__________________
Cowboy Logic: Bad decisions usually make good stories!
1964 Thikol 1202 CrewCab "Sold"
1972 Bombardier SV250S
1987 LMC 3700 CF
1998 M923A2 5-Ton
The Following User Says Thank You to KickerM For This Useful Post:
m1west (03-22-2020)
  #42
Old 05-20-2020, 04:57 PM
m1west m1west is offline
m1west is on a distinguished road
Hi all, The last trip to the cabin, on the way down I started to get a little hot where I had to stop and add water a couple of times.
What I found at home is the bottom of the upper radiator hose had a hole in it. Not sure how it happened, the hose was not rotted and it was cut through the string reinforcement. I don't know how it could have got cut by abrasion where the cut was located. I put a new hose on it and when I tested it I could see the weep hole on the water pump weeping a little. I ordered a water pump and timing belt kit figuring that while I am in there I should change the belt too. It showed up yesterday so I put it on today. Tomorrow I will fill it with water and test my work, then button it up and take it back to the Mountain as I have decided to just leave the tracks on it fr summer use. The terrain there is very steep with loose dirt. If I put tires on it I'm not sure it will climb the hills. The whole reason to have it up there is to be able to drive around on the property. If I have to stay on the roads it defeats the purpose. So that being said I will soon order a set of tracks for the Van and get it ready for winter.
The Following 5 Users Say Thank You to m1west For This Useful Post:
1boringguy (05-21-2020), J5 Bombardier (05-20-2020), jim slagle  (05-20-2020), KickerM (05-22-2020), PJL (05-20-2020)
  #43
Old 05-21-2020, 05:49 PM
Today I buttoned up the timing belt/ water pump installation added water, ran it, burped the system. the temperature is stable and no leaks. Tomorrow I am going to pull it off of the trailer and give it a good long test, then add coolant and go to the mountain.
The Following 2 Users Say Thank You to m1west For This Useful Post:
KickerM (05-22-2020), PJL (05-21-2020)
  #44
Old 05-22-2020, 07:01 PM
Today I pulled it off of the trailer. Then took it for a ride around the property a good long while, loading it hard. It is about 80 degrees today which is a lot warmer than the winter at the mountain and about as hot as it gets there in the summer. Tomorrow I will drain the water and add coolant, then put the bumper and radiator cover back on, clean it up and put it back on the trailer. Next week I am going back to the work cabin and can report how it does on the mountain. I am getting ready to order a new set of tracks for the van.
I settled on Mattracks EZ UTV for up to 3500#, the van loaded with people and luggage will be around 2000#. The Mattracks have a little larger foot print than the Compulast tracks so they should do well. $4,100.00 plus shipping with no adapters or anti rotation. They wanted $1500.00 for the brackets and spacers, its a weekend in the shop making them and mine on the Suzuki are much stronger than the store bought. 16 weeks lead time.
I plan to go ahead and change the water pump, hoses and timing belt on the van when I put the tracks on to get ahead of any maintenance that could cause me problems in the snow later.
So far I am very happy with the performance of the Suzuki. If I had done the water pump and hoses when I got it I wound not have had any issues at all.
The Following 3 Users Say Thank You to m1west For This Useful Post:
1boringguy (05-23-2020), jim slagle  (05-22-2020), KickerM (05-23-2020)
  #45
Old 05-22-2020, 08:10 PM
alryA alryA is offline
alryA is on a distinguished road
Seem you'll do better with Matts than the Camos pods. I always wanted to run some but never had the opportunity..
The Following User Says Thank You to alryA For This Useful Post:
m1west (05-22-2020)
  #46
Old 05-22-2020, 09:32 PM
Quote:
The Camso pods were a trade deal where I didn't have to buy them, so far I have nothing bad to say about them. The Suzuki went everywhere I needed to go with them without any problems at all. I don't see any obvious ware happening to anything. I am an amateur compared to you guys that work them for a living.
I am going with the Mattracks because they are a little cheaper and the SQ. inches are a little more, thats it. I use them for cabin access in the winter and the Suzuki will be used in the summer. They both may see 75 to 100 miles each year, so they should last for a while. I don't know the speed at which you groom at but most of the time I am running about 10 mph on narrow, steep with switchbacks, snow covered mountain road that if your lucky a skid steer hasn't roughed everything up real good for you. Its about 5 miles off grid. When I get the Mattracks and put them on I will post it.
1boringguy (05-23-2020), KickerM (05-23-2020)
  #47
Old 05-24-2020, 06:30 PM
Finally, got it all buttoned up, put the bumper and radiator cover on. While I was there I did some other maintenance as I noticed the front tracks were a little toe out so made that adjustment, also when braking up a steep hill from flat the passenger side rubbed the body a little so I made that adjustment. All the work was tested then I cleaned it up. Next week I am going back to the mountain with it. The week after I will do the lift kit then a water pump, timing belt and hoses the van. Might as well head the problems off up front.
Backyardski (05-25-2020), jim slagle  (05-24-2020), KickerM (05-24-2020)
  #48
Old 05-24-2020, 10:01 PM
KickerM's Avatar
Check your articulation angles on the tracks, my first set of camoplast tracks would hit when I would come into a steep incline (aka blowing into a plow bank to scare the bejesus outta my passengers)
__________________
1987 LMC 3700 CF
1998 M923A2 5-Ton
m1west (05-25-2020)
  #49
Old 05-26-2020, 06:27 PM
Just ordered a new set of Mattracks EZ UTV 3500# tracks for the Van. $4123.00 plus shipping. 50% deposit 12 week delivery time. Now I have all of the components, while I'm waiting it will give me some time to get the lift kit, Timing belt and water pump installed before they show up. The MAXIMS would have been nice but they are almost double the cost of the UTV tracks at over $7,000.00 for less than 600 sq. more track. The Camso tracks on the Suzuki are about 100 SQ. inches smaller than the EZ UTV tracks and they worked good on the Suzuki so the UTV tracks should be good on the Van.
jim slagle  (05-26-2020), KickerM (05-26-2020)
  #50
Old 05-27-2020, 07:15 PM
Made it to the cabin today, took a few minutes to play with the Suzuki a little. I will do some more testing later in the week. I have a COOT and it will not do this. So far so good, you can stop on this angle in loose dirt and take off again you're not going to do that on tires.
The Following 4 Users Say Thank You to m1west For This Useful Post:
1boringguy (05-28-2020), Backyardski (05-28-2020), jim slagle  (05-27-2020), KickerM (05-27-2020)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Suzuki Carry Japanese mini truck new to me m1west ATV's / RTV's / UTV's / Side-by-Side's Forum 26 01-03-2020 03:43 PM
SOLD-2005 Suzuki 4X4 MINI TRUCK w/Mattracks dzuppio Snowcat Classifieds (For Sale / Wanted) Forum 12 08-22-2017 03:51 PM
Dominator tracks on a Suzuki Samuri mtntopper Snowcat Adventure & Usage Forum 2 03-13-2015 01:56 AM
mini truck with tracks fails Snowtrac Nome Snowcat Adventure & Usage Forum 13 12-11-2009 02:33 AM
Haflinger -or- Mini Truck -or- RTV ??? Melensdad ATV's / RTV's / UTV's / Side-by-Side's Forum 46 04-12-2006 09:18 AM
Copyright 2002 - 2020 www.ForumsForums.com
