Tucker Sno-Cat 1982 318 Dodge 2 bbl Low Hours with snowmobile drag
Track Addict
Drag has to be worth a few thousand. So 7000 sounds reasonable. Only thing that sounds odd is the master cyl causes hydraulics to leak? Must be a control valve for hydraulics.
Master for clutch break etc should be separate and self contained. Plan on a few thousand into whatever you buy.
JAGEmpire
Thanks Track Addict......it's very interesting...does pulling a drag tend to weaken the clutch....I will keep you posted!
