Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Snowcat Repairs, Parts & Problems Forum > THIOKOL/LMC/DMC Technical Issues Forum
THIOKOL/LMC/DMC Technical Issues Forum Technical repair issues & questions for Thiokol/DMC/LMC
Reply
Thread Tools Display Modes
  #1
Old 02-28-2017, 12:32 PM
DWester DWester is offline
Junior Member
DWester is on a distinguished road
Default 1404 differential oil
I know that this is a redundant question and I apologize for that, but after reading many post on this, I'm scratching my head more now than before I started. From what I've picked up, I think the differential I have is a C-4? The year I'm not sure of, other than in the manual it says 1969. Of all the oils mentioned, which will be the best for me?
  #2
Old 02-28-2017, 12:41 PM
cloudcap's Avatar
cloudcap cloudcap is offline
cloudcap is on a distinguished road
Default Re: 1404 differential oil
I've been using Shell Donex TC-30 based on Snowcat Pat's recommendations. So far it has been working pretty well for me.
FYI, here's a link to a previous post of mine describing my first foray into my Imp's differential.
Have fun.
Ron
The Following 2 Users Say Thank You to cloudcap For This Useful Post:
DWester (02-28-2017), snow (05-04-2017)
  #3
Old 02-28-2017, 01:04 PM
Junior Member
Great thread Ron!! Just what I was looking for. Did this statement turn out to be true? "Once I've got everything exposed, how much do I tighten the bands? An earlier thread on Super Imps suggested that you should tighten the nut to 200 inch pounds and then back off a couple turns. Barring better advice, that's my plan." Or is that only on Super Imps?
  #4
Old 02-28-2017, 01:17 PM
cloudcap's Avatar
No. I only tightened the bands to where I had a small-ish amount of travel on the little levers on the top of the differential before they engaged. I know that's pretty vague, but I didn't want the bands to be too tight. The "200 inch pounds" approach sounds more precise and may actually be the proper way to do things, but I felt more comfortable winging it. So far it has worked OK.
Ron
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
OC-15 differential camp_corrupt Snowcat Repairs, Parts & Problems Forum 5 07-26-2012 12:34 AM
differential ???? timandkim Snowcat Repairs, Parts & Problems Forum 4 03-02-2011 09:14 AM
name this differential? MNoutdoors Snowcat Restoration & Modification Projects Forum 6 01-04-2011 10:30 AM
Looking For M-24 Differential MNoutdoors Military Vehicles Forum 1 08-08-2008 05:16 PM
OC-15 Differential MNoutdoors Snowcat Repairs, Parts & Problems Forum 3 04-11-2008 12:13 AM
