What size are the lines for the water? You should be able to do regular heat tapes and use the foam tubes to cover them with. Modern heat tapes have thermostat ends on each one. If your runs are not that long they work great. always put the split seam down and tape the seams between pieces. Wish I was closer I could fix you up quick as I have done a lot of mobile homes over the years. The valves for the holding tanks will be the toughest to insulate but plastic sheeting alone helps to hold the heat in. You might need to use fiberglass on the valves and wrap them good with plastic and tape. I would not sweat the tanks if you use some antifreeze in them. Make sure the thermostats are left outside the insulation on the tapes or they wont work.
