Snowy Rivers
Busy morning...had to help a friend out.
We installed an Easy lift hitch on her pickup/tailer.
Got that done and continued to thrash on THE WLT
Getting all the wiring loose on the engine and chassis.
The lift lugs on the cab are nearly complete.
Front ones bolted on to the lugs the front fenders bolt to by the door hinges.
Re-purposed the flat hooks off some old semi trailer flat strap ties downs that were worn out...(Garage sale thing $5 for a box full)
Cut the straps off and then welded a ring on the outside to grab with the ratchet straps.....
No need to modify the rear lower wall of the cab...
Easy grab under the rear wall...stick some cardboard between the back of the cab and the hook to keep from munging up the cab......
Early tomorrow we will go for a lift......
If fortune favors the foolish.....the little "Soon to be cat cab" will be swinging in the wind....
Will get pix when it happens......
