Reply
Thread Tools Display Modes
  #1
Old 04-07-2017, 11:10 AM
hansoni's Avatar
hansoni hansoni is offline
hansoni is on a distinguished road
Default Thiokol 1402 1404 parts
Wondering if the 1402 and 1404 have the same rear, linkage for shifting the rear, steering components, and track length/# of grousers, and trans?
  #2
Old 04-11-2017, 02:19 AM
Two Track Mind Two Track Mind is offline
Junior Member
Two Track Mind is on a distinguished road
Default Re: Thiokol 1402 1404 parts
I have one of both models . The slave cyl. ,master cyl. , shift linkage is the same . The same rearends but not sure if ring/pinion ratio is the same . I put the 1402 rearend into my 1404 because of broken teeth on ring gear and it all works fine but I believe the 1402 D-Dent ratio might be higher than the ratio in the 1404 WT model .My 1404 is capable of 30 mph downhill but with both transmissions in first feels higher geared than 1402 was in first. Remember that the D-Dent [standard track ] sprocket is smaller because of grouser design . The brake slave cyl. mt. plate was more robust on the 1404. Wide track/ narrow track axle assembly's interchange. My finger is sore ,I'm done .
  #3
Old 04-11-2017, 05:48 AM
hansoni's Avatar
Thanks. I wondered if the 1402 was more or less the same as the 1404 with just a different power plant and nose assembly. I see these come up for sale cheap might be worth it for spare parts. I have an extra 1.7 motor maybe figure a swap and build a new cab.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
WTB: 1402 Imp Parts: Slave/Master cylinders & Grousers (24 inch) wasatchjohn Snowcat Classifieds (For Sale / Wanted) Forum 6 06-27-2016 12:04 AM
Thiokol 1402 Vermont Track Addict Snowcat Classifieds (For Sale / Wanted) Forum 18 10-10-2014 08:00 PM
Thiokol Imp 1402 PrecisionMarine Snowcat Restoration & Modification Projects Forum 15 10-16-2011 01:24 PM
Thiokol 1402 S/N 136 Chetdb Snowcat Repairs, Parts & Problems Forum 10 10-13-2011 02:26 AM
1964 1402 thiokol imp kehoe585 Snowcat Classifieds (For Sale / Wanted) Forum 0 01-14-2010 10:04 AM
Copyright 2002 - 2017 www.ForumsForums.com
