Reply
Thread Tools Display Modes
  #161
Old 01-26-2016, 09:01 PM
Snowtrac Nome's Avatar
Default Re: Snow Trac replacement BRONZE drive sprockets
it may only be 8 mph in the 2100 but those j grousers are like ice skates when on ice. its not Vin Diesel, its Ford Dorset diesel
__________________
Don
1962 st-4
KL2ZF
The Following User Says Thank You to Snowtrac Nome For This Useful Post:
mbsieg (01-26-2016)
  #162
Old 02-22-2016, 02:36 PM
redsqwrl's Avatar
redsqwrl redsqwrl is offline
redsqwrl is on a distinguished road
Any news on the WA sprocket process?
the WI process is under way.
I will be pulling a copy sprocket soon. Ill post here if I have success.
The Following User Says Thank You to redsqwrl For This Useful Post:
300 H and H (02-22-2016)
  #163
Old 02-22-2016, 04:58 PM
Bombi1 Bombi1 is offline
Bombi1 is on a distinguished road
My foundry has both patterns and is going to make one of each. Am expecting to hear from him any day. They have been very busy, so it has taken longer than expected.
The Following User Says Thank You to Bombi1 For This Useful Post:
Rbenjamin30 (02-24-2016)
  #164
Old 02-24-2016, 12:39 PM
redsqwrl's Avatar
Copy ST 30A sprocket was pulled Monday.
pattern maker corrected it for shrinkage in both the tabs and ears Tuesday.
Just got a call that 5 will be poured today.
Five more on Monday.
(these are the TWO BAND Sprockets)
if you in a bind send me a note. Ever since the Dairy queen run, My poly sprockets are skipping steady now on the right side. I could not wait. I need to use the machine to pull Ice houses off the lake.
Sturgeon spearing ends Sunday, fish houses have to be pulled off before 3/2
I got one yesterday, our warm weather and warm water temps are eating the ice from both sides.
300 H and H (02-24-2016)
  #165
Old 02-24-2016, 01:35 PM
300 H and H's Avatar
300 H and H 300 H and H is offline
300 H and H will become famous soon enough
So what did this years fish weigh?
Glad you got those sprockets getting poured. Just remember where you got the one you made the pattern from!!
Can't wait to see how they turn out.
__________________
Snow trac ST4 #267
  #166
Old 03-03-2016, 10:29 PM
Finally got a sample of both sprockets cast. They turned out good.
Have a picture but could not figure out how to post it here.
Anyone interested in a set can PM me and I can email the picture
and we can go from there.
Thanks
John
  #167
Old 03-28-2017, 09:59 PM
SnowTrac Hunter's Avatar
SnowTrac Hunter SnowTrac Hunter is offline
SnowTrac Hunter is on a distinguished road
300 H&H had posted dimensions previously for sprockets. Neils sent me an STP file which I could open with Wedge, but without having a compatible version of AutoCAD I couldn't dimension.
The dimensions that were posted in this thread were slightly incorrect, so I am trying to correct per layout. I am going to try and make a weekend trip to verify. Three hour drive and couple mile hike in to cabin. The dimensions below are what I have come up with so far. Please feel free to correct me if I am off base.
Outer Tooth Diameter - 17-1/4" (17.25")
Outer Tooth Radius - 8-5/8" (8.625")
Base Diameter - 15-3/8" (15.375")
Base Radius - 7-11/16" (7.6875")
Tooth Degrees - 90*, 77.1428571*, 51.4285714*, 25.7142857
Circle Circumference - 54.19247"
Tooth Center to Tooth Center - 3-7/8" minus (3.8708")(14 Teeth)
Tooth Tip Width - 1" (Need to Verify)
Space at Base - 1-1/2" (Need to Verify, May need to be 2" for grouser which would take out slope)
Thickness - 1/2" to 1" UHMW depending on model.
Hope this is helpful. I have an older two band model. I would like to start out with 1/2" and see if it is durable enough before I modify my sprocket to fit thicker UHMW. Prices of UHMW vary depending on location. I purchased a piece of 18" x 10' for $350 in Anchorage, Alaska. You may be able to find cheaper in the Lower 48.
Thanks,
Joe
__________________
Joe Billy
1964 ST4 #446
The Following User Says Thank You to SnowTrac Hunter For This Useful Post:
nikos (03-30-2017)
  #168
Old 04-03-2017, 04:39 PM
Dimensions will need to be modified from what was posted -
Tooth Width - 3/4"
Tooth Space at lower radius - 1-7/8"
Mounting Hole radius - 5-7/8"
Mounting Hole Size - 1/2" for 3/8" bolt
Inner Hole Radius - 5-1/8" (10-1/4" Diameter)
Will update picture of template when finished modifying for new dimensions.
Thanks for your patience,
Joe
__________________
Joe Billy
1964 ST4 #446
Snowshadow (04-03-2017)
  #169
Old 06-21-2017, 11:15 PM
Cidertom's Avatar
Cidertom Cidertom is online now
Cidertom is on a distinguished road
Thanks
John
Back on the trail of sprockets. Are these a send check, get sprocket item or still a one-by-one prototype?
Or who has >right now< st50/52 3 band sprockets for sale or short turn around time.
CT
  #170
Old 06-29-2017, 10:06 PM
Cidertom's Avatar
bump.
  #171
Old 06-30-2017, 03:01 AM
PM sent
  #172
Old 09-13-2017, 11:50 AM
Cidertom's Avatar
New sprockets arrived to replace the slightly worn ones.
It appears the previous owner(s) never flipped them.
Thank you Bombi1
The Following 6 Users Say Thank You to Cidertom For This Useful Post:
300 H and H (09-14-2017), Bombi1 (09-13-2017), night-owl (09-13-2017), nikos (09-14-2017), redsqwrl (09-13-2017), Sno-Surfer (09-13-2017)
  #173
Old 09-14-2017, 08:29 AM
DAVENET's Avatar
DAVENET DAVENET is offline
DAVENET is on a distinguished road
Holy cow. Actually seeing a new one of those has been a long time coming.
  #174
Old 09-14-2017, 08:56 AM
Yes it has. Some are being made out of UHMW plastic as well. They probably will not last as long, but will be quiet and easy on the grousers in the track.
__________________
Snow trac ST4 #267
  #175
Old 09-14-2017, 09:48 AM
Cidertom's Avatar
I really thought about using UHMW plastic. If I had the older type, I probably would have gone that way. I just didn't like the long unsupported spokes of the ST52. Thought about doing a hybrid, metal core and using the older style for the drive part. Then thought my time would be better spent drinking beer, and not re-inventing the drive wheel.
  #176
Old 09-14-2017, 10:54 AM
JimVT's Avatar
JimVT JimVT is offline
The bolt pattern very on the st4 and I'm curious if you need to redrill them.
__________________
Jim KF7RiN
#185 snow trac
2004 pistenbully canyon
  #177
Old 09-14-2017, 11:36 AM
Cidertom's Avatar
They have no holes as yet. Going to clamp the old to new and bore them.
  #178
Old 09-14-2017, 02:58 PM
Beartooth Beartooth is offline
Beartooth is on a distinguished road
Are the ST-30a two band being produced. I have two machines and would put UHMP on one and bronze on other for a test. Either way I need them.
Doug
  #179
Old 09-14-2017, 04:31 PM
Cidertom's Avatar
send a PM to bombi1, but he may be slow to respond due to mother nature.
  #180
Old 09-22-2017, 10:45 PM
Cidertom's Avatar
Got time to drill and mount the new sprockets. They are thicker than the old ones. Not enough to be an issue though. But the nylocks barely have enough stud. Going to go through the mounts this weekend and check bearings etc.
The Following User Says Thank You to Cidertom For This Useful Post:
nikos (09-23-2017)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Snow Trac TOYS Melensdad Snowcat History, Articles, Manuals, Brochures & Recollections Forum 43 01-19-2013 11:27 PM
looking for a Snow trac! Tommo Snowcat Adventure & Usage Forum 22 02-12-2006 01:38 AM
SNOW TRAC -Polish Website Translated to English (sort of) Melensdad Snowcat History, Articles, Manuals, Brochures & Recollections Forum 0 01-20-2006 05:55 PM
schmidt's Snow Trac at MOUNTAIN HOME LODGE Melensdad Snowcat Restoration & Modification Projects Forum 6 01-10-2006 02:56 PM
