Go Back   Forums Forums - Off Topic Forum FUN > Vehicles > Cars, Trucks Forum
Reply
Thread Tools Display Modes
  #1
Old 06-01-2016, 10:43 AM
NorthernRedneck's Avatar
NorthernRedneck NorthernRedneck is offline
Platinum Member
NorthernRedneck will become famous soon enough
Style: T66
Default Suspension leveling kit
Anyone here ever attempt a suspension leveling kit on their truck? I'm not looking to lift it an additional 2 feet in the air and install big swamper tires. All I want to do is lift the front end two inches so it's sitting level with the back.
I've done a bit of research on the ford f150 and apparently ford did away with the torsion bar setup in 2003. On my old durango I just cranked the torsion bars up a few turns to get it sitting level and increase front end clearance. Most pickups nowadays have that butt up in the air look with the back end being 2-3" higher than the front.
So here's what I'm looking at doing to mine......
And I plan on doing it by installing......
It looks to be an easy install. Basically just take the front suspension apart as if you were changing a strut then install the spacer over the top of the strut then reinstall everything. Should be about a 2 hour job. Of course it runs about $200 on average for the spacers but I consulted my go to parts place(ebay) and found the exact same set of spacers that normally sell for $200 listed for $38. So I will be ordering a set.
  #2
Old 06-01-2016, 11:29 AM
bczoom bczoom is offline
Style: T66
Default Re: Suspension leveling kit
I thought you did a lot of hauling/trailering.
If you lift the front then put your camper on the back, you'll be nose up (which sucks since your headlights are now pointing into the trees).
My truck sits the same as the before image above. If I want it level, I'd just toss some sandbags in the bed.
__________________
If you didn't hear it with your own ears or see it with your own eyes, don't invent it with your small mind and share it with your big mouth.
The Following User Says Thank You to bczoom For This Useful Post:
mtntopper (06-01-2016)
  #3
Old 06-01-2016, 12:35 PM
EastTexFrank's Avatar
EastTexFrank EastTexFrank is offline
Gold Member
EastTexFrank will become famous soon enough
Quote:
That used to be my answer for snow and ice as well. I used to leave them in there most of the year as I thought that they made the truck ride better, until I needed sand for some project around the house.
__________________
ETF
I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them. John Wayne as JB Books in "The Shootist".
  #4
Old 06-01-2016, 12:54 PM
Style: T66
Quote:
I know the ride in my truck is much more civilized when I have 300-500# of weight in the bed.
__________________
  #5
Old 06-01-2016, 01:51 PM
jwstewar's Avatar
jwstewar jwstewar is offline
jwstewar is on a distinguished road
Mine too. I even changed my rear springs out for ones from a 2500 which raised the rear even more. I cranked the T-bars 2 or 3 rounds I think, help some, but it still has a heck of a rake to it. Of course, since it rarely leaves the yard anymore without towing/hauling it is sitting level most of the time.
__________________
Jim
http://facebook.com/floweringgoatfarm
Revelations 22:12 And, behold, I come quickly; and my reward is with me, to give every man according as his work shall be.
  #6
Old 06-01-2016, 06:54 PM
pixie's Avatar
pixie pixie is offline
Silver Member
pixie is on a distinguished road
I read Toyota truck forums a lot. Some people consider those spacers dangerous as in 'another thing to break' because they can suffer sideways torque.
Most people use either adjustable Rancho RS9000 shocks which you can change with a dial on the unit or Bilstein 5100 shocks which you can set to different heights when you install them.
My #1 choice since you tow would be sandbags. #2 the Rancho shocks.
__________________
Live Free or Die
  #7
Old 06-01-2016, 10:51 PM
PBinWA's Avatar
PBinWA PBinWA is offline
Master of Distraction
PBinWA will become famous soon enoughPBinWA will become famous soon enough
Style: VB_Original_Style
I lifted my last F250 and it seemed to just result in a series of other issues: ball joints, steering issues, faster tire wear. Of course then you'll want the bigger tires, and you'll need new shocks, and .....$$$$
__________________
A government big enough to give you everything you want, is strong enough to take everything you have.
-Gerald Ford
  #8
Old 06-01-2016, 11:45 PM
Av8r3400's Avatar
Av8r3400 Av8r3400 is offline
Gone Flyin'
Av8r3400 will become famous soon enough
If it ain't broke, don't fix it.
__________________
Av8r3400
I'd rather die trying to live,
than live trying not to die.
-Leonard Perry
The Following 2 Users Say Thank You to Av8r3400 For This Useful Post:
EastTexFrank (06-02-2016), jimbo (06-02-2016)
  #9
Old 01-17-2018, 03:19 PM
Platinum Member
Style: T66
Quote:
Well, I had taken your advice and didn't bother with the front lift even though I had the spacers sitting in the garage. I had the truck in the shop the other day getting upper and lower balljoints changed on the drivers side when they discovered a broken front spring. How I broke a spring with only in town driving is beyond me. Anyways, they wanted $280 just for one strut assembly. Ebay provided me with 2 moog struts for $125. Since I'm changing out the struts I'll have them install the spacers. I'm not worried about trailering with this truck anymore. The plan is to keep it a year then trade for something newer.
The Following 2 Users Say Thank You to NorthernRedneck For This Useful Post:
Doc  (01-17-2018), jim slagle  (01-17-2018)
  #10
Old 01-17-2018, 05:32 PM
Doc's Avatar
Doc Doc is offline
Forum Admin
Doc will become famous soon enoughDoc will become famous soon enough
Cold weather is hell on our equipment. And you are in some of the coldest weather of us all. Good luck Brian.
__________________
Scott me up Beamy.
Other Fun Forums:
Weekend Mudders + Net Tractor and RTV Talk + Net Cooking Talk
The Following User Says Thank You to Doc For This Useful Post:
  #11
Old 01-19-2018, 05:20 PM
Platinum Member
Style: T66
The ford is now in like new condition mechanically. She's got a new set of duratracs, brake rotors, pads, calipers, front wheel bearings, struts, ball joints. She's got some minor surface rust but I haven't seen a vehicle over 4 years old up here without some form of rust. Something is nolt right when the streets are still wet at -40. They have been using a new liquid salt that does a good job with ice but eats away at the paint.
Back to the lift. The front end feels a lot higher now with the extra 2". Also. Going from front springs and shocks that had 200k on them to new ones sure made a difference in the ride on the front end. Feels like new.
Sent from my GT-P7510 using Tapatalk
The Following User Says Thank You to NorthernRedneck For This Useful Post:
jim slagle  (01-19-2018)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
J5/SW-XX Suspension benz9 Snowcat Restoration & Modification Projects Forum 8 02-17-2010 11:23 AM
Suspension Cletis Snowcat Restoration & Modification Projects Forum 6 11-07-2009 03:53 PM
Sweet! Leveling the Sugar Hills scooterd Snowcat Adventure & Usage Forum 2 10-27-2009 04:09 PM
Need advise on pasture leveling/repairing ??? BigAl Agriculture & Rural Living Forum 8 09-14-2007 12:12 AM
Leveling Mower Deck BoneheadNW Lawn, Garden, Plants & Trees Forum 3 04-26-2006 07:03 PM
