So I have done a ton of searching and even a couple of direct phone calls and I am convinced that there is not a VW application for the heater boxes.
I found a discussion about a member who fit 1200 or 1500 heat boxes to a dual port 1600 with some fabbing.
I found this from L.S. "ST4 heater boxes after 1963 are NON STANDARD. They took standard heater boxes ad reworked the nozzles to accomodate the variator towers. All the work was braised sheetmetal. Prior to 63 they had "Stale Air", stay away from these. They only fit 40 Hp and smaller. Only a couple of years of 40 HP have clean air boxes and the tubing is small diameter so it won't fit anything else. My buddy Earl rebuilt several and even modified some 1600 boxes from scratch, just the way they did at the factory, with tin snips and a braising torch. It's tedious, but do-able. Take NEW heater boxes to a welding shop, and some old ones to compare them against. We also found that it was handy to have a transmission and complete engine block , on a dolly arraingement so that you could test fit them without having to try and force the motor in and out of the engine compartment. Believe me that this is one of the most arduous tasks on restoring an ST4."
I have a VW Bug motor from 1974 (AH) that motor came with extra heater boxes and they fit sort of close. instead of trying to find the boxes from a van or bus (single exhaust outlet) I think I will be cracking out the welder and die grinder to chop of the valves and turn the valves to miss the towers,
has any one had any luck finding a heater that is close. My VW Guru is thinking that early bus are what we need, they are J style and head off to the side, I am going to find a pair and see..
What do you know?
Mike
What do you know?
Mike
