Kicker
You can do a lot of work on those two machines....
Tooling is the part that cost the Bucko's
I picked up a lot of my tooling off ebay.
Many would turn their nose up at some of my tooling because it was made overseas....fact is the stuff is not bad at all.
Not sure it would hold up in a production shop.... but for a hobby application its fine.
Carbide cutters are expensive.....but again, watching ebay can net some good finds of Aerospace contract over stock items very very inexpensive....
I see you have a 4 jaw chuck
These are so handy for getting hold of odd shaped items and being able to dial in an existing bore to do whatever is needed..
Also...grabbing a square or rectangle chunk of material and working on it..
The younger crowd will scoff at anything less than a CNC to machine parts.....but this country was built with machines far more crude than the manual ones you and I have.....
If the spindle is tight on the lathe as well as the ways being fairly snug and the cross feed...if you can hold tolerance to .002" you can do most stuff you will need for what we do..
Now if you need to get down into the .0005" range we are talking a different story.
If you are careful and you can finesse things a bit you can gitterdone..
Thanks for sharing the pix....
Olympic
Yes exactly 1987 K Burb
I dragged that mount out mostly to see if there was any good reason to go barking up the tree about stuffing a 454 in the Cat.
I am not really excited about that cross member as it takes up a lot of space...
See the piccy of the motor mount for SB/BB Chevy....a good maybe.
This set up is far simpler and will keep the belly access open to allow working on things....Like the starter...
I don't want clutter.....
There is going to be plenty of that anyway.
The Chevy V8 will sit such that access down through the DOGHOUSE in the van should make things like the distributor an easy reach....
I simply do not know yet where this will all wind up.
A radiator capable of cooling the big Rat is my biggest worry....
The 2100 front end is only 28 inches wide.....just not enough room down there for a big core.
It may be an idea to do a larger than stock radiator up in the Van location... and add a couple big electric fans..
Plumbing the coolant hoses should not be that big of an issue...
I wanted to be able to roll the van chassis back for good access to the engine....but with the radiator up in the van this will be an issue..
Ah hell....we will take it one step at a time..
I am definitely leaning towards this idea of the V8 power and all the drive train down in the cat as it was....
I was looking at the Cat yesterday and once the cab is off and the firewall/bulkhead is cut away...(Tilt cab 2100 has a bulkhead that the cab sits down over and bolts to...you can see it in the picture with the chevy mount) the tub will be wide open.
The existing rear tranny mount MAY be usable as is with only minor modifications....Gonna take a trial fit with an engine/tranny package in there.
Shifter linkage for the tranny is likely going to be best handled with a cable type unit.....
Maybe a floor mount......still a lot of pencil and paper and tape measure work to do.... but the entire package seems workable.
I really want to be able to use the entire dash cluster as is in the Van though.
Locate the battery in the van battery tray and wire things in using the stock harness "With slight mods)
Today though it is back to yanking out the old hydraulic hoses and getting ready to remove the cab......
I do have ads on Craig's now hunting for a couple roaches to scarf up an engine and tranny and a Van body....
And here we goooooooooooooooooooooooooooo....
