When it comes to the design, the vertical shaft engine is superior.
Here is why:
Oil delivery.
The horizontal design puts a little "scooper" on the bottom of the connecting rod's end cap. There must be enough oil in the crankcase for it to reach it, and splash it all over the inside of the crankcase - and lubricate the moving parts. So, for example: If you have a engine with that setup that has a 26 oz oil capacity, and it falls below the reach of the scooper.. it will seize or fail due to lack of lubrication.
The vertical shaft doesn't need a scooper because the crankshaft is not above the oil, it is going right through the bottom of the crankcase.
So, even if there is only 2 OZ of oil left in there - the spinning shaft is in that oil, and that will "whip up" enough to throw oil the the rest of the engine.
The reason I know this is true - is because I had yet another (seen this many times) lawn mower come in for a tuneup - That had no oil show up on the dipstick. Draining the oil provided about 2 OZ!!! That is 18 OZ low!!
No mechanical damage. Just very low on oil.
You could never get away with that with a horizontal shafted engine.
Anyone agree?
Here is why:
Oil delivery.
Anyone agree?
