Go Back   Forums Forums - Off Topic Forum FUN > Agriculture & DIY Forums > DIY Forums > DIY Plumbing Forum
Reply
Thread Tools Display Modes
  #1
Old 12-12-2017, 11:29 AM
bczoom bczoom is offline
Super Moderator
bczoom will become famous soon enoughbczoom will become famous soon enough
Style: T66
Default Need help with plumbing issue
My son was bringing firewood up to the house last night. Got his sweatshirt caught in the ATV throttle while getting off. The ATV took off, sideswiped the house and sheared off the outside water spigot.
There's not enough pipe sticking out to solder or attach a sharkbite around the outside of the pipe.
Looking for ideas/options for connecting a new spigot but need to go inside the existing pipe unless I start tearing out mortar.
Not sure how well I could do a sweat joint since it's embedded in the brick so ideally, I'd like to find a self-tapping or compression fit connector that would go inside the existing pipe.
I checked SharkBite connectors site and I don't see they make something like this.
Ideas?
__________________
If you didn't hear it with your own ears or see it with your own eyes, don't invent it with your small mind and share it with your big mouth.
  #2
Old 12-12-2017, 11:37 AM
TiredRetired's Avatar
TiredRetired TiredRetired is online now
Mr Lovable
TiredRetired has a spectacular aura aboutTiredRetired has a spectacular aura about
Default Re: Need help with plumbing issue
I'm not much of a plumber but I'll toss my hat in the ring.
I would go and rent a Hilti or similar electric hammer drill, chisel away the mortar and find good pipe to connect to. I am not familiar with sharkbites so I cannot help in that regard.
If you are going to all that trouble, may as well just cut the pipe all the way back into the basement and install a anti siphon frost free silcock, but what the hell do I know.
After all that, maybe a protective bollard to make is son safe would be in order.
__________________
Walls are NOT immoral.....Abortions Are.
The Following User Says Thank You to TiredRetired For This Useful Post:
bczoom  (12-12-2017)
  #3
Old 12-12-2017, 11:55 AM
Super Moderator
Style: T66
I'm sort of thinking along the same lines you are if I can't attach something from the outside (which is my hope).
__________________
  #4
Old 12-12-2017, 12:40 PM
EastTexFrank's Avatar
EastTexFrank EastTexFrank is offline
Gold Member
EastTexFrank will become famous soon enough
Not sure that I can help you much as I'm not aware of anything that seals inside the existing pipe. All my outside spigots are the freeze free type and the only time that I've had to replace one I had to drill and chisel out the mortar to get it out of the wall. I've used sharkbites but only on PEX, never on copper so I can't vouch for that either.
Let us know what you decide to do as it may be helpful in the future.
__________________
ETF
“I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them.” John Wayne as JB Books in "The Shootist".
The Following User Says Thank You to EastTexFrank For This Useful Post:
bczoom  (12-12-2017)
  #5
Old 12-12-2017, 12:53 PM
Super Moderator
Style: T66
I've used the SharkBite's on copper. They work very well.
If I'm pulling out a drill and/or tearing up the interior wall, it'll wait until Spring. It's too damn cold to do it now and the water to that spigot is already shut so it can wait if needed.
If I could just pop something in from the outside, I can do that in the winter.
__________________
  #6
Old 12-12-2017, 01:05 PM
Gold Member
I just had a thought. There is a tool called a tubing or pipe swager. I haven't seen one used in years but it was just a die that was placed inside the pipe and hit with a hammer. They probably have fancier versions by now but it opened the end of the pipe enough to slide another section of pipe in to it. It may not work in your case since the pipe is surrounded by mortar. The internet is your friend.
__________________
ETF
Doc  (12-12-2017)
  #7
Old 12-12-2017, 01:10 PM
Doc's Avatar
Doc Doc is offline
Forum Admin
Doc will become famous soon enoughDoc will become famous soon enough
Wow, he really sheared it off. Lucky he didn't get hurt. I agree with the others, I know of no way to fix that other than tearing up the mortar, and if you are doing that you might as well replace it with another anti freeze one. I'm afraid there is no easy fix for this.
__________________
Scott me up Beamy.
Other Fun Forums:
Net Tractor and RTV Talk + Net Cooking Talk
  #8
Old 12-12-2017, 01:31 PM
Super Moderator
Style: T66
Quote:
Maybe then, I'd have some pity on him but for now, I'm just pissed.
Besides taking out the spigot, he took off the dryer vent cover and hit an antique marble table. If that table had broke, I'd be seriously pissed. The dryer vent is an easy fix.
__________________
The Following User Says Thank You to bczoom For This Useful Post:
Doc  (12-12-2017)
  #9
Old 12-12-2017, 03:09 PM
road squawker's Avatar
road squawker road squawker is online now
road squawker is on a distinguished road
go inside the house and cut off the pipe.
Solder a new smaller pipe to it and run the smaller pipe thru the old one, it's just a hose bib so you really won't notice the slight loss of water volume.
or,...(best solution), knock out the mortar and replace with all new piping.
The Following User Says Thank You to road squawker For This Useful Post:
bczoom  (12-12-2017)
  #10
Old 12-12-2017, 03:48 PM
Mr Lovable
Well, that idea of a bollard is looking better and better.
__________________
bczoom  (12-12-2017)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Weird issue with bathroom plumbing jpr62902 DIY Plumbing Forum 6 03-19-2015 12:29 AM
Joe's Affordable Plumbing Act of 2014 Doc Jokes_Forum 5 01-19-2014 02:33 AM
PEX plumbing review BigAl Home Improvement Projects, Appliance upgrades, Misc Household items Forum 9 03-14-2011 10:32 PM
Joe's Fair Plumbing Act PBinWA Jokes_Forum 1 10-30-2008 07:48 PM
Amercan Standard Plumbing issue Junkman Home Improvement Projects, Appliance upgrades, Misc Household items Forum 2 01-11-2008 02:51 PM
Copyright © 2002 - 2018 www.ForumsForums.com
