st4 axle shaft needed
peter keg
The splines are gone on my front axle shaft & chain driven sproket.If anyone has these parts please contact me.
Sprocket 39 tooth
front axle shaft
78 snow trac st4
Thanks
Peter
Peter i have the parts you need but i don't know if they are the same as mine is for a 2 band track maby some body could lend some advice.
peter keg
Thanks Don.I can take some measurements of mine & get them to you.A friend of mine owns a Machine Shop So I am also going to check with him on making new ones.will post pics of my snow trac soon
they are pretty soft the drive sprockets are the same but i don't know about the axle shafts as long as he has a way to cut the splines wont be to hard to make one he may be able to notch it for a couple of key ways to and you could put it back together that way and it would be just as strong.
