Snowy Rivers
Yes....The belt drives need to be smooth for sure...
How difficult is it to change the belt once things are together ?????
Or if you want to stand on your head, you can use the access door from inside the cab with a normal wrench. What I've found is for simple belt on -off. I don't have to touch the bottom nut. I just use the top. adjusting tension as the belt stretches you have to do both. But, the newer belts stretch much less than the OEM so it's not that common to do. When I rebuilt mine, I used reflective tape on the output gears and a photo tachometer to get the speed even from left to right. The speed is visibly different in the video I did.dead simple really, just need to slacken it, but the bottom tensioning nut is difficult to get at - needs a special cranked spanner.
