Go Back   Forums Forums - Off Topic Forum FUN > Snow Trac ST4, Kristi, Thiokol/LMC, Tucker, Bombardier & Other Snowcat Discussions > Snowcat Restoration & Modification Projects Forum
Snowcat Restoration & Modification Projects Forum Major Restorations, Upgrades, and Non-Stock Snowcat Modifications
Reply
Thread Tools Display Modes
  #81
Old 06-05-2019, 08:25 PM
sno-drifter's Avatar
sno-drifter sno-drifter is offline
sno-drifter is on a distinguished road
Default Re: 1542 conversion to a 1543 supersized project
Quote:
Originally Posted by olympicorange View Post
can t say that I know of any of those in our area...the swedes built some crazy stuff... they were used all around the world....built by volvo ??
They must have got the idea from Tucker. Build the cab around the drive train.
The Following User Says Thank You to sno-drifter For This Useful Post:
olympicorange (06-08-2019)
  #82
Old 06-05-2019, 10:41 PM
Cidertom's Avatar
Cidertom Cidertom is offline
Cidertom is on a distinguished road
I had a fire engine that was built that way. The body builder welded the subframe around the chassis members trapping the pump. We wound up cutting the back out of the cab to perform what should have been a simple 1 hour repair.
I learned a thing or two about contract specifications ... a a few new words.
  #83
Old 06-10-2019, 06:46 AM
olympicorange's Avatar
olympicorange olympicorange is offline
olympicorange is on a distinguished road
. mocking up alignment of 4BT/AT545... a helpful trick ; to align t/c adapter ring mounting threads & flexplate holes for hardware, is to use a long stud , to line-up the first hole...
The Following 6 Users Say Thank You to olympicorange For This Useful Post:
Doc  (06-10-2019), jim slagle  (06-10-2019), loggah (06-10-2019), Northcoast (06-10-2019), PJL (06-10-2019), wbuffetjr1 (06-10-2019)
  #84
Old 06-16-2019, 06:22 PM
.... tapped threads in output drive flange of AT545 which secures the parking brake drum & intermediate driveshaft. drilled & tapped a ''locator'' bolt for p.b. drum to flange. reinstalled trans....removed 4BT from rotator stand. went for a F/D's ride . found a few drags... notice rear tires removed for the season...
The Following 4 Users Say Thank You to olympicorange For This Useful Post:
DAVENET (06-17-2019), jim slagle  (06-16-2019), Northcoast (06-23-2019), redsqwrl (06-17-2019)
  #85
Old 06-22-2019, 09:38 AM
only had 5 minutes this week...
The Following 2 Users Say Thank You to olympicorange For This Useful Post:
jim slagle  (06-22-2019), Northcoast (06-23-2019)
  #86
Old 06-22-2019, 11:50 AM
MNoutdoors's Avatar
MNoutdoors MNoutdoors is offline
Tracked Evolution Central
MNoutdoors is on a distinguished road
What was the TIR? (total indicator runout) just curious
__________________
I had a conversation with dirt the other day, It promised me that when I die it's got me covered
The Following User Says Thank You to MNoutdoors For This Useful Post:
  #87
Old 06-22-2019, 04:09 PM
Should be .002" or less
The Following 2 Users Say Thank You to sno-drifter For This Useful Post:
jim slagle  (06-22-2019), olympicorange (06-22-2019)
  #88
Old 06-22-2019, 04:12 PM
Quote:
...roger that . was .001'' .. as sno-drifter said... over .002'' then you'll have wear issues,... trans. input seal weepage...etc...
The Following 3 Users Say Thank You to olympicorange For This Useful Post:
DAVENET (06-24-2019), jim slagle  (06-22-2019), Northcoast (06-23-2019)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1980 Tucker 1543 Cedar City Utah - Not Mine wannagoflying Snowcat Classifieds (For Sale / Wanted) Forum 2 06-17-2018 04:52 PM
Not mine----1543 Tucker with blade CoFarmer Snowcat Classifieds (For Sale / Wanted) Forum 3 05-23-2018 11:21 AM
Blade for 1543 Tye one on Snowcat Restoration & Modification Projects Forum 4 12-19-2017 09:25 AM
First run for 1543 Tye one on Snowcat Adventure & Usage Forum 7 12-19-2016 12:41 PM
