So we have a customer that brought us a Muskeg carrier with a crane on it and they said it only steers one way, well here is why!
It still moved,but to turn left you had to back up and pull the right lever till it was pointed where you wanted it to go.then forward for a ways, then backup to repoint the front, if going forward, over and over. Turning right worked just fine
A broken drive axle can do it also, that would have been to easy.
Also a broken steering band will also act the same.
