So you have a used Snow Trac, Trac Master or Snow Master? Thats right, the ones made in Sweden with the modified VW Transaxel for steering and a VW flat 4, horrizontally opposed, air cooled engine.
Elsewhere in this Forum are the answers to just about any question you could have concerning an ST4. Some questions have been addressed 3,4 and 5 times. It's all right here. You'll have to do a bit of searching.
#ONE: The previous owner took the Air Induction Horn off and threw it away!
BAD! VERY BAD!. If yours is gone, make a new one! Otherwise your engine will over heat, eventually "Suck-A-Valve", sieze up, and leave you stuck in some place that you don't want to walk out of! AND your "Triple-A" card won't work, they don't offer tow service for snow cats broke down on the side of MT. Rainier!
#TWO: The previous owner(now reffered to as "Idiot", and not the one from John Muir's book!) has taken off, and discarded some of the "Deflector Tin" from the engine compartment. This also results in overheating problems. BUSTED!, GO DIRECTLY TO JAIL!, DO NOT PASS GO! DO NOT COLLECT 300$,PAY BIG FINE!!(Exception: If you live north of the Arctic circle, and only operate your machine when it is below about MINUS 10, NEVER HUNT IN IT, and operate on entirely FLAT Terraine you MIGHT GET BUY, but I wouldn't ride with you.)
#Three: The prebvious owner removed the Snow Thrower Flaps: BAD, VERY BAD!! Results in busted AXEL Housings!! Definately NOT GOOD!
NOW click that mouse, search around, read all those articles especially the one Mike, and Bob, and I wrote. It's all right there. About 100 years worth of accumulated Snow Trac Experience.
So instead of spending your time trying to fix the busted down track rig, you can spend your time out having fun playing in the snow.
THE 3 MOST COMMON MISTAKES
