Reply
Thread Tools Display Modes
  #1
Old 03-04-2019, 12:44 PM
partsman11 partsman11 is offline
Junior Member
partsman11 is on a distinguished road
Default Skidozer bolt on wheels
I have been trying to find some 12" wheels for my Skidozer. I went and looked at a parts machine SV-250 that had bolt on wheels separate from the hub. Was this a factory setup from Bombardier? Will these hubs fit my machine?
  #2
Old 03-04-2019, 06:54 PM
undy undy is offline
undy is on a distinguished road
Default Re: Skidozer bolt on wheels
My SV-252 has 1-piece wheels that do not unbolt from the hub.
I don't know if your hubs are factory or not, nor whether that setup might fit my spindles. But that's definitely different than what's on my cat.
__________________
Bones heal and chicks dig scars.
If I die in my ski boots, I win. In fact, I hope to die skiing - just not today.
It is better to go skiing and think of God, than go to church and think of sport. Fridjof Nansen
  #3
Old 03-04-2019, 07:18 PM
MNoutdoors's Avatar
MNoutdoors MNoutdoors is offline
Tracked Evolution Central
MNoutdoors is on a distinguished road
The bolt on wheels were factory in the early years the spindles are smaller and two different sized bearings
The later models had larger bearings (2788) and both the front and the back are the same size
__________________
The Tracks you leave today, Will lead you to the future!
  #4
Old 03-12-2019, 09:46 PM
Junior Member
Thank you for the info
  #5
Old 03-13-2019, 10:21 AM
Ski Lima's Avatar
Ski Lima Ski Lima is offline
Formerly Backyardski
Ski Lima is on a distinguished road
Is that the same size hub and bolt pattern as on the bombardier mp? Those have 5.3-12’s
  #6
Old 03-13-2019, 10:57 AM
MNoutdoors's Avatar
No those are different size that's larger
__________________
  #7
Old 03-15-2019, 11:51 AM
Junior Member
Bogie
Would I be able to use the entire assembly (Flexitor,Axle arm, spindle and wheel) on another machine?
I have a SV 301 that now has 29" tracks. The first axle and (Bogie) wheel has a wheel with the bearing that is correct. I would be installing the next 4 on both sides.
If I did this, would I set the flexitor angle up for the SV 301?
The parts machine is a 1970 SV-250 Th flexitors are all facing the same direction.
I also need more steel grousers for the 301. Would I call MN Outdoors or PM you direct?
  #8
Old 03-15-2019, 12:24 PM
MNoutdoors's Avatar
Quote:
Originally Posted by partsman11 View Post
Bogie
I believe you could use the entire assembly the axles are a little weaker but should work
Yes,contact www.mn-Outdoors.com for the 29 cleats currently INSTOCK
__________________
  #9
Old 03-15-2019, 03:03 PM
Junior Member
I will contact Mn Outdoors
Would you have the flexitor direction and angle chart?
I found one on this site from a SV 250 manual
Is it the same for the 301 Frame or will I need to get a manual for it?
  #10
Old 03-15-2019, 03:56 PM
MNoutdoors's Avatar
Here is the settings
__________________
  #11
Old 03-15-2019, 08:50 PM
Somebody should make that diagram a sticky!
__________________
The Following User Says Thank You to undy For This Useful Post:
Ski Lima (03-16-2019)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Track bolt patter Rat Track Snowcat Adventure & Usage Forum 1 07-20-2015 09:14 AM
Tucker Trunion Turntable bolt ? Track Addict Snowcat Repairs, Parts & Problems Forum 5 08-07-2014 09:31 AM
Russian Bolt ons....who's seen em?...... On Topic berg Snowcat Restoration & Modification Projects Forum 3 01-08-2014 10:47 PM
WTB 5 bolt large wheels or 6 bolt hubs couchloafer Snowcat Repairs, Parts & Problems Forum 8 02-09-2009 12:46 AM
