Instead of a light bulb, wouldn't it be best to stick an ammeter in there and see what the draw is? That may help point in the right direction.
Aftermarket stereos and amps almost always seem to be the culprit so even though he pulled it out, make sure the wiring is back to where it would have been before the aftermarket "stuff". Also, was one or more new hot wires pulled for the stereo? (depending on the amp in particular, OEM wiring may have been inadequate and a new wire capable of handling more amps would have been run). If that's the case, find where it is being pulled from and disconnect it on that side as well. I've seen more then one crappy wire pull where the insulation was worn off from rubbing on something. Normally, between the firewall and under the dash.
