JimVT
i'm stuck on finding a 40 yr old part that John deere doesn't make anymore. idid a search with the part number and came up empty.
part is C503E Hub can anyone help? it is a cap that slides over the axle hub shaft that you remove when replacing the tire. the cap is cast an i removed it in chunks after ordering the part. then i was told they no longer have it.
wheel bolts to the hub and needed part slides over the axle then bolts to the outside body/frame to support the wheel.
the auger has been removed because i just cut weeds with it now.
